Activity Forums Apple Final Cut Pro Legacy Capturing from Ch 3 + 4
  • Capturing from Ch 3 + 4
    Posted by Outis on April 7, 2006 at 9:09 pm
    Hello,
    I have a DVCam tape and the audio I need to capture is on Ch 3 +4 , I have it switched on my deck to play those tracks and I hear the audio, no problem. But when I capture, FCP captures from Ch 1+2. WRONG AUDIO! Anyone ever deal with this issue and know how to fix it?
    Thank you!
    Rennie Klymyk replied 20 years, 1 month ago 4 Members · 3 Replies
  • Creative Animal jan
    April 7, 2006 at 9:15 pm
    Did you check a3+4 in the capture settings tab in the log and capture window?
    Are you capturing using videointerface or via firewire?
  • Bouncing Account needs new email address
    April 7, 2006 at 9:18 pm
    FCP must be set to access Ch. 3 & 4.
    Here’s how (it is the same for PAL, but you will of course use the PAL settings):
    Final Cut Pro (menu pull-down) >
    Audio/Video Settings >
    Capture Presets >
    Click the “Duplicate…” button >
    a new “Capture Preset Editor” window will open >
    Change the “Name:” field to DV NTSC 48 kHz CH 3&4 (so you’ll be able to tell it apart from the “normal” setting.)
    Under QuickTime Audio Settings >
    Input: Second 2 Channels >
    Click “OK”
    Now, try a capture. If the audio is on CH 3&4, you’ll get it into FCP.
    Remember to put your “normal” settings back (to “First 2 Channels”) after you captured CH 3&4 tracks.
  • Rennie Klymyk
    April 7, 2006 at 9:23 pm
    What is your system? Some i/o’s only pull in channel 3+4 if there is audio on 1+2. You may have to switch your leads to your input device to input them on ch 1+2.
    sloburn
