Activity Forums Adobe Premiere Pro Capturing from Beta SP player in Premiere Pro CS6
  • Capturing from Beta SP player in Premiere Pro CS6
    Posted by David Geysar on December 26, 2012 at 10:09 am
    Hi guys,
    I am a novice so any help will be highly appreciated.
    I have Premier Pro CS6 and I need to capture some Beta SP tapes. I have The Sony UVW-1800P which is connected to my Blackmagic Multi Bridge Pro. I can capture using the Multi Bridge Media Express but I would like to know how to communicate with the player using Premier. When I open Capture I cannot see the device.
    Thanks in advance
    David
    Ian Kane replied 13 years, 8 months ago 3 Members · 6 Replies
  • David Geysar
    December 26, 2012 at 11:12 am
    I figured it out, I updated the driver for my Multibridge and now I can see Blackmagic in Premier Pro’s capture devices list.
  • David Geysar
    December 26, 2012 at 12:03 pm
    Back again with another problem. Although I can now capture from the Beta SP, I can’t export to tape from Premier Pro CS6, every time I get a flickering Still image with “Playing on video hardware” in several languages. My device control settings is correct as it is set at Blackmagic. Has anyone experienced this and is there a way around it?
  • Dennis Radeke
    December 27, 2012 at 3:08 pm
    This might help you – Setting up 3rd Party i/o
  • David Geysar
    December 27, 2012 at 9:16 pm
    thank you Dennis, I had a look at the tutorial video in your link, although very helpful, I am still having problems exporting to tape. Basically what happens is when I try to export to tape, the Beta SP starts fast forwarding until the end of the tape and then nothing happens. Could this have anything to do with the Time Code? I have tried various tapes and still have the same issue. I have set the TV on the SP to External.
    Has anyone got the following setup:
    Mac system
    using Blackmagic Multibridge
    using Sony UVW1800P
    using Adobe Premiere Pro CS6
    Can someone please tell me how to export to tape, since this is Digital to Analog I have having a lot of trouble.
    thanks
    ps. I can capture without any issue!
  • Ian Kane
    December 31, 2012 at 2:35 pm
    Regards,
    Ian Basil Kane
  • Ian Kane
    December 31, 2012 at 2:38 pm
    I am having the same issue when trying to print to tape. “Playing on video hardware.”
    Snow Leopard
    CS6
    Sony DVCam deck (DSR-2000)
    Final Cut Pro 7 prints to tape just fine.
