Activity › Forums › Apple Final Cut Pro Legacy › Capturing from a Z1U
Posted by Brach Pulver on March 21, 2011 at 4:08 pmI have been using the Sony Z1U for a year or so now and all of the sudden today I put a tape in that has some important footage on it and it will not show the footage. The timecode will run and the footage will show while in FF or REW, but not in regular playback.
Any ideas or do I just have a bad tape? I have tried other tapes and they are working.
David Roth weiss replied 15 years, 4 months ago 4 Members · 6 Replies -
Zane Barker
March 21, 2011 at 4:23 pmDid you record HDV or DV with that camera?
is the camera set to output HDV or DV?
Is FCP set to receive a HDV or DV signal?All of those things must match.
**Hindsight is always 1080p**
Andrew Rendell
March 21, 2011 at 5:12 pm+1
It’s probably one of those menu settings, most likely one at the camera end if you’re seeing something when it’s spooling. -
Brach Pulver
March 24, 2011 at 2:18 pmI have tried the footage in another camera with the same result. I can see it while spooling and not in regular playback. Anything????
Zane Barker
March 24, 2011 at 2:20 pmTelling me you tested it on another camera does not answer any of the questions I asked. So again.
Brach Pulver
April 19, 2011 at 2:25 pmDid you record HDV or DV with that camera? HDV
is the camera set to output HDV or DV? HDV
Is FCP set to receive a HDV or DV signal? HDVAgain, I have been doing this for a long time with this camera without a problem, I am at a loss. Any idea what could be going on here??
David Roth weiss
April 19, 2011 at 4:40 pmIs iLink set to “on” in the camera menu? If so, turn that setting off.
David Roth Weiss
Director/Editor/Colorist
David Weiss Productions, Inc.
Los Angeles
https://www.drwfilms.comPOST-PRODUCTION WITHOUT THE USUAL INSANITY ™
A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
