Activity › Forums › Adobe Premiere Pro › Capturing from a JVC GY200e to cs5 HDV
  • Jeff Pulera
    January 13, 2012 at 2:41 pm
    If you want to capture native HDV via 1394, then use an Adobe HDV sequence and do that. After capture, you ought to be able to then edit those clips in a BlackMagic sequence so that you can get the output preview.
    Jeff Pulera
    Safe Harbor Computer
