Activity › Forums › Apple Final Cut Pro Legacy › capturing “free run” recorded tapes
  • capturing “free run” recorded tapes
    Posted by Annaël Beauchemin on August 15, 2005 at 6:11 pm
    I have a cassette on which was recorded alot of very small shots (2-5 sec each) using free run timecode. There is no timecode drop (ie no blank part), but of course when I try to capture the entire tape, FCP stops at each timecode break and make a new clip.
    Since I’m going to do speed changes with the footage, I worry about problems if I disable the “make new clip on break” option. Has anyone ever dealt with this situation?
    I could duplicate the tape with a new timecode… but right now I can’t.
    Annaël Beauchemin replied 21 years, 1 month ago 2 Members · 2 Replies
  • Bouncing Account needs new email address
    August 15, 2005 at 9:08 pm
    The best method is to make a FireWire copy of the tape to another camcorder or deck which will generate a new continuous TC. (You said you can’t do this but did not say why.)
    This will give you a new solid TC which will allow for accurate batch capture and will allow all recorded frames to be used in the edit.
    Another method is to Capture into FCP with the setting for Non-Controllable Device (which IGNORES any TC on the tape).
    You can edit from this capture at your own risk, as you will not be able to RE-capture accurately if needed.
    BUT, if you do this capture and THEN just turn around and copy it back OUT to the camcorder on a new tape, the camcorder will then generate new continuos TC on the new tape.
    You’d then get rid of the captured (non-TC) footage in FCP and RE-capture only from the new copy with the capture settings returned to DV “controlled” this time. (The only reason to use this method is if you don’t have two DV camcorders with which to make a direct tape-to-tape FW copy.)
    There will be no generation-loss with either method because during the FW transfer, the DV files are unaltered.
  • Annaël Beauchemin
    August 15, 2005 at 9:50 pm
    [Matte] “The best method is to make a FireWire copy of the tape to another camcorder or deck which will generate a new continuous TC. (You said you can’t do this but did not say why.)
    Simply because I do not have another deck. Oh, I do have an canon elura10, but with broken tape mechanism (surprise?).
    ahh, that’s what I should have used… I decided to capture it making new clips nonetheless, since time was running up, but i’ll remember that one. In fact, if I have time i’ll give it a try to see if speed changes are reliable using this method.
    thanx
