Activity Forums Apple Final Cut Pro Legacy Capturing Footage with Final Cut Pro
  • Capturing Footage with Final Cut Pro
    Posted by Stefani Natalia on December 14, 2006 at 7:14 pm
    I have a problem with the timecode on my tape. When the footage plays, the timecode does not play with it (it stays still all the time). When I capture the footage, Final Cut keeps locating timecode break and cueing the tape. Is there a solution for this? -Thanks!
    Todd Gillespie replied 19 years, 9 months ago 2 Members · 1 Reply
  • Todd Gillespie
    December 15, 2006 at 6:05 pm
    Under the user prefs there’s a check box for timecode breaks, uncheck it and see how far you get.
    If that doesn’t work, the switch the device control to ‘non-controlable’ device, then just hit play on your deck.
    One of those should do it.
    Good Luck,
    Todd at UCSB
    Television Production
