Activity Forums Apple Final Cut Pro Legacy capturing footage with cheapo camera
  • capturing footage with cheapo camera
    Posted by Tielman Dewaele on June 27, 2007 at 1:14 pm
    Hello,
    I want to capture a lot of tape(MDV). But i dont want to use my Canon xl2 for this, because the of the heads.
    I want to use a cheap handy cam, to capture all my tapes.
    Will it affect the quality of the footage? Because the footage i have are shot pretty good.
    Need advice on this.
    The camera is a cheap simple sony handycam…model doesnt mather
    FCP Studio 5.0
    MacPRo quad core. OSX
    Firewire to capture…
    THANKS
    T.
    Peace
    13 replied 19 years, 2 months ago 4 Members · 3 Replies
  • Stace Carter
    June 27, 2007 at 1:26 pm
    This makes perfect sense – since you’re going firewire/digital it’s just data, so if you experience dropouts, etc they should be major and noticeable, but that would be an alignment issue and not a “quality compromise” per se.
  • Lee Berger
    June 27, 2007 at 1:58 pm
    Since you are capturing data over FireWire there is no playback quality difference between el-cheapo and your XL2.
    Lee Berger
    http://www.leebergermedia.com
  • 13 Create COW Profile Image
    13
    June 27, 2007 at 5:08 pm
    I have seen some cheepo cameras only play back the tapes that they recorded, most likely this is because the cheeper heads become misaligned more easily.
