Activity › Forums › Panasonic Cameras › Capturing footage from AJ HDX900
  • Capturing footage from AJ HDX900
    Posted by Helen Burdess on April 7, 2010 at 9:47 am
    Hi, really need some help with this! I have some footage that was shot in the U.S. on a panasonic AJ HDX900E at 1080/60i.
    I can play the tapes back ok in our panasonic hdx900, and have the camera connected up to FCP with firewire, but when I am trying to digitise the footage i have a couple of problems:
    – I cannot control the tape through final cut pro, which is really frustrating! which means i have to use the capture now instead of logging the tape and batch capture (we dont have log sheets)
    – using the capture now keeps flagging up lots of timecode breaks which arent in the original tape
    – once the footage is digitised and played in the fcp viewed, the audio goes out of sync
    does anyone have any ideas which A/V setting i should be using ? I currently have it set on are:
    sequence preset – DVCPro HD 1080i60
    capture preset – DCVPro 1080i60 48KHz
    Device control preset – Firewire NTSC
    would really appreciate any advice anyone has as ive never worked with NTSC footage before!
    thank you
    Helen Burdess replied 16 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
