Activity Forums AJA Video Systems capturing f900 help!
  • capturing f900 help!
    Posted by Nayim Saati on October 20, 2009 at 10:08 pm
    In a bit of a big jam here heres the issue:
    i got some HDCAM tapes that were shot with the sony-f900. I am trying to capture them and having some difficulties. The tapes came back with the 30p mark checked off on the label of the tape (the deck also says 30p>>1080 as read from the tape) so i set the deck frequency to 29.97Psf and it plays fine. but when i capture the video and then check out the results the video plays super fast and the audio is obviously way out of sync… im not entirely sure what capture presets to use on my final cut. im capturing through my aja card on my apple G5 btw. also im trying to capture all onto a g-raid 3TB hooked up firewire 800. so anyways i dont exactly see the perfect capture settings out of my aja options in capture preset. any ideas?? i need help! sorry im just starting out and am trying to learn all the frame rates and frame sized and shooting modes but not there yet…
    please help!
    Jeremy Garchow replied 16 years, 11 months ago 2 Members · 3 Replies
  • Jeremy Garchow
    October 20, 2009 at 11:07 pm
    Sounds like you are trying tocapture 24psf. Set your easy setup to 1080i and try again. You might want to think about posting the the Kona forum as this is the KiPro forum. Thanks!
    Jeremy
  • Nayim Saati
    October 21, 2009 at 12:25 am
    if i set the deck to 24psf then it wont play the audio though??
  • Jeremy Garchow
    October 21, 2009 at 1:41 pm
    You want to keep the deck @ 29.97 psf. Then use the 1080i easy setup in FCP.
