Activity Forums VEGAS Pro Capturing DVD
  • Capturing DVD
    Posted by Carlo Simone on August 26, 2006 at 4:36 am
    Hi all,
    Does anyone know of a really good DVD ripper that converts to avi or mpeg?? I have tried many however I have had no luck so far. I seem to have lots of trouble importing a dvd to Vegas even though I use the import feature. Vegas always craps out with a critical error eveytime I do it. I sometimes seem to get a few clips into the media bin but then Vegas won’t play back the file in the timeline?
    I guess my main question is, what’s the best way to do capture and edit a dvd in Vegas?
    Thanks..
    Rj Miles replied 19 years, 11 months ago 5 Members · 4 Replies
  • Adam Rose esq.
    August 26, 2006 at 5:34 am
    I found simply copying the files on to the drive, then changing the .vob extension to .mov, then throwing it on the timeline
    works for me
    I use dvdshrink to rip, when necessary, tho don’t know what gives best quality
  • Edward Troxel
    August 26, 2006 at 1:27 pm
    While many people disagree with this, a way that works consistently is to connect your DVD player to a convertor and capture via firewire while playing the DVD into a standard DV-AVI file. DV-AVI is much easier to edit than MPEG2 and you don’t have to worry the other problems you’ve been experiencing.
    Edward Troxel
    JETDV Scripts
  • Allen Zagel
    August 27, 2006 at 2:49 pm
    If your not ripping a copyrighted, copy protected DVD a lot of us are using a newer program called Cinematize. It’s a life saver if a client sends you a DVD and you need to get the original back on the timeline to re-edit.
    I tried the “change VOB to MPG” route but I didn’t care for the quality and it’s hard editing MPEG2
    Allen
    ASX Media Productions
    https://www.asxvideo.com
  • Rj Miles
    September 18, 2006 at 6:24 am
    May I add I think I have found a nice new way to grab encrypted goodies.
    FairMount to mount the DVD as a decrupted volume icon on the decktop.
    DVDxDVPro to access the VOB files, which allows for in/out edit points, batch capturing, and a wide range of QT movie format options.
    I’m working on a wedding video for my sister, and I have had a tough time getting a couple of goofy things off of our commercial DVDs. I tried using HandBrake, which works great if .mp4 will do. However, I wanted to avoid a 2nd level of batch recompression or long importing and the new method above seems to be a great method.
    DVDxDVPro is a commercial program that would not read a commercial DVD alone, but with the FairMount decyption plug, I can now access DVDs other than my client projects DVD masters.
    RJ
    May I also say, there is a difference between ripping to the Apple Intermediate Codec and any of the DV/DVCPro/DVCPro50 formats. I get alot of alaising with the DVD codecs. I test rendered to a couple of uncompressed codecs, and the Apple Intemediate Codec appears as clean but much smaller in size.
