Activity › Forums › Broadcasting › capturing DVCPro on a DSR-1500AP
  • capturing DVCPro on a DSR-1500AP
    Posted by Michael Duff on September 1, 2005 at 6:50 am
    We have a DSR-1500AP and when I playback my DVCPro tape I get vertical lines all over the screen. The lines are about 10pixels wide and evenly spaced. I can sort of see the vision behind, but it is not very clear. I’m not sure if it is shot DVCpro50 or 25. And in fact I have not had any experience with this deck or format in the past. ANy ideas where to start?
    Cheers in advance
    Tony replied 21 years ago 3 Members · 5 Replies
  • Jon Zanone
    September 1, 2005 at 3:42 pm
    Get a Panasonic deck. You can’t play back DVCPro on a Sony deck…
  • Michael Duff
    September 2, 2005 at 12:36 am
    doh – are you positively sure????? cause when I look up the deck on google everywhere says it can playback DVCpro…. https://www.bhphotovideo.com/bnh/controller/home?A=details&Q=&is=REG&O=productlist&sku=285375
    https://www.broadcast.com.tr/partners/sony/dsr1500ap.asp
    Thanks for your help
  • Jon Zanone
    September 2, 2005 at 3:39 am
    What you describe sounds like DVC Pro 50 being played in a 25 deck, hence my assertion that Sony can’t play DVC Pro. In my sleep deprived response, I should have said it can’t play back DVC Pro 50. Is your source tape 50? Remember, you can shoot 50 on a 25 tape, so don’t go by what the tape label says. Of course I’ve seen a really wierd artifact on 25 where a reused tape showed both the old shot and the new shot on the same frame. I’ll have to dig that out and steal a frame from it – it’s kinda’ weird….
    Jon
  • Michael Duff
    September 2, 2005 at 3:54 am
    it must be 50. Cheers for the help.
  • Tony
    September 8, 2005 at 3:34 pm
    The dsr 1500A only plays back dvcpro which is 25mb 4:1:1. DVCPRO 50 is 50 mb 4:2:2 and will not playback on the dsr-1500A. DVCPRO 50 playback requires a Panasonic vtr which is capable of playing back dvcpro 50.
    FYI when playing back dvcpro in the dsr-1500A the only active outputs are the analog outputs not the firewire.
    Tony Salgado
