Activity › Forums › Adobe Premiere Pro › Capturing DVCPRO hd to cs6
  • Capturing DVCPRO hd to cs6
    Posted by Heather Doleman on April 16, 2013 at 11:19 pm
    I am trying to capture DVCPRO HD to a AJ1400. I have set the AJ1400 to factory defaults and I am trying to use the firewire out. I can control the deck but I do not see any picture or hear any audio. Does anyone know of a special setting for the recorder that will solve my problem? I can capture HDV footage from a camera through the same cable with no trouble at all. But I have some DVCPRO HD footage that I would like to capture.
    Thank you.
    Eric
    Tim Kolb replied 13 years, 5 months ago 3 Members · 3 Replies
  • Heather Doleman
    April 17, 2013 at 12:37 am
    I meant to say from an AJ1400
    Eric
  • Greg Jones
    April 17, 2013 at 2:56 pm
    I have the exact same deck. If you have another program, such as Final Cut Pro, you could capture through that program then import the footage into Premiere. I’ve had a lot of issues digitizing footage into Premiere so I always digitize in Final Cut Pro then import into Premiere. Hopefully they will fix the issue in CS7.
    Greg Jones
    D7,inc.
    Orlando,Fl.
    https://www.d7-inc.com
    Greg Jones
    Orlando,Fl.
  • Tim Kolb
    April 17, 2013 at 5:12 pm
    I don’t believe that Premiere Pro supports that deck via F W…it was kind of a special FCP thing as far as I knew…did Avid support that method of capture?
    TimK,
    Director, Consultant
    Kolb Productions,
    Adobe Certified Instructor
