Activity Forums Apple Final Cut Pro Legacy capturing dv to external drive with imac
  • capturing dv to external drive with imac
    Posted by Brian Pitt on October 22, 2007 at 6:27 pm
    I am having a hard time capturing video with my imac. There is no problem if I capture to the internal hard drive, but I’m trying to capture to a firewire 400 external drive. When I’m in the log and capture window, as soon as I play any video to log an in and out point, the screen freezes. It will continue to stay frozen until I stop the video source. I’m capturing standard dv via firewire. It’s the new intel imac, so I can’t understand what the problem is.
    Sarza replied 18 years, 10 months ago 3 Members · 4 Replies
  • Jeff Carpenter
    October 22, 2007 at 6:57 pm
    What did you format the firewire drive as? It should be Mac OS Extended, non-journaled.
    If you used anything else, copy all data to the iMac, re-format it, and copy the data back.
  • Brian Pitt
    October 22, 2007 at 9:45 pm
    I’m not sure…but that sounds like it might be the issue. I’ll give that a try tonight at home and let you know. thanks.
  • Brian Pitt
    October 24, 2007 at 3:50 am
    Hey Jeff,
    I re-formatted my drive and I’m still getting the same problem. Any other ideas?
  • Sarza
    November 18, 2007 at 10:47 am
    I am having exactly the same problem. Did you find a solution? Can anyone else help?
    Sarah
