Activity › Forums › Adobe Premiere Pro › Capturing dv footage?
Posted by Matthias on January 26, 2006 at 7:54 pmI’ve been using a firewire cable for the past few years to capture dv footage to premiere, is there a different way to capture the footage in a way to improve quality?
Kylesway replied 20 years, 7 months ago 3 Members · 3 Replies -
Shane Chadder
January 26, 2006 at 9:04 pmNo. Firewire is a straight data transfer so you are making a perfect copy. Anything else is processing the signal.
Matthias
January 26, 2006 at 9:14 pmawesome thanks, i just saw something about dv decks being the best way to capture dv footage, but it could have beed about the hdv decks, i dont know.
Kylesway
January 30, 2006 at 9:45 amHi Matthias
the thing about using a separate deck has nothing to do with quality,
at least not of the transfer. It is recommended to use a separate
deck to limit the amount of wear you expose the way more fragile
drive that’s built into the camera to. This is most important if
your capture program keeps running the tape back and forth at each
new clip. I’m not sure how PPro does it (think I remember at least
1 was doing it this way) as I use ScenalyzerLive which can capture
and scene/clip-split a tape in a single play-through.— Kyle
