Activity Forums Apple Final Cut Pro Legacy Capturing directly to sequence
  • Capturing directly to sequence
    Posted by Tom Bucknall on February 23, 2011 at 8:12 pm
    Does anyone know of a way to capture video directly to an open FCP sequence?
    Background: We are currently cutting a 60 min program with a lot graphics and as such we are laying the graphics on in a linear session. Basically we play the show onto two digibeta tapes, then using an edit controller and a BlackMagic Decklink we key the graphics from one tape to the other doing a video insert only.
    I’m trying to cut the tapes out of the equation and possibly the edit controller so I’m wondering if by using a KI Pro and FCP it would be possible to mark an in and out point on a sequence and capture onto a second video track above the original from the KI Pro + graphics. Obviously the timecode on the KI Pro and the FCP sequence would be identical and I could achieve the same thing by Log and Capturing but I would rather have the captured clip fall straight onto the sequence rather than the editor have to line it up manually.
    I’ve looked at Virtual VTR but at £599 I’d rather see if it’s possible my way first.
    Thanks.
    Steve Eisen replied 15 years, 6 months ago 4 Members · 3 Replies
  • John Pale
    February 23, 2011 at 8:22 pm
    FCP does not have this feature. Avid does have it, but I have never used it.
  • Francois Jean
    February 24, 2011 at 1:05 am
    There is away to do this using “open” quicktime files…
    This is describe in TELESTREAM pipeline user guide, but I not shure if you can generate such files without a pipeline.
    ZAP
  • Steve Eisen
    February 24, 2011 at 4:43 am
    Check out ToolOnAir. You can drop your clips in the timeline while you are still capturing.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
