Activity Forums Apple Final Cut Pro Legacy Capturing DigiBeta to ProRes
  • Capturing DigiBeta to ProRes
    Posted by Andrea Stewart on March 9, 2010 at 5:03 pm
    I’m capturing through an AJA IO SDI. I thought I would edit in ProRes in order to save drive space and make use of my multicore. In the past I’ve always worked in 10bit uncompressed start to finish.
    Is there a way to capture using the ProRes codec from my AJA?
    -Andrea
    Andrea Stewart
    Producer/Editor/Director – Owner
    Germane Creative LLC
    Rafael Amador replied 16 years, 5 months ago 2 Members · 3 Replies
  • Rafael Amador
    March 9, 2010 at 5:11 pm
    In the “Capture Presets” duplicate the one you use for 10b Unc; edit the preset and change the codec to the Prores flavor that you want.
    Rafael
    http://www.nagavideo.com
  • Andrea Stewart
    March 9, 2010 at 5:16 pm
    Cool. Thanks Rafael. Just did that.
    Can I confirm that when working in NTSC I want to make sure I go to advanced and click capture interlace Lower Field first.
    Also will there be any advantage to capturing ProResHQ when working from Digibeta? And would I get drive space savings vs 10bit uncompressed?
    Andrea Stewart
  • Rafael Amador
    March 10, 2010 at 1:23 am
    [Andrea Stewart] “Can I confirm that when working in NTSC I want to make sure I go to advanced and click capture interlace Lower Field first. “
    Don’t worry about this.
    FC won’t allow to build a capture preset NTSC 10b “UPPER FIRST”. Only Lower.
    [Andrea Stewart] “Also will there be any advantage to capturing ProResHQ when working from Digibeta? And would I get drive space savings vs 10bit uncompressed? “
    Everything will be easier and you will achieve the same quality.
    rafael
