Activity › Forums › AJA Video Systems › Capturing digi
  • Capturing digi
    Posted by Christian Vassallo on October 6, 2008 at 11:08 pm
    Hi guys
    I’ve recently set up my new suite and have been having an issue with capturing digi. This might end up being an FCP question rather than a Kona question but please bear with me.
    When capturing digi into FCP i was initially using an AJA Io and have since upgraded to a Kona 3. I have been capturing Uncompressed 10 bit PAL and working on a timeline to suit that format – i set it up in easy setup and checked all the settings afterwards in a/v settings.
    The thing is that the quality of the captured image isn’t as sharp as i know it should be coming from digi and being uncompressed 10 bit.
    It’s pretty good, but I have noticed a few jagged edges on some high contrast areas like peoples sleeves, if they’re wearing a white t shirt for example. It’s been driving me crazy because i don’t know why it is happening. I know it’s not the tape or the deck because i plugged the deck into an avid suite and the picture was perfect on the broadcast monitor.
    I thought it might have been the AJA Io but the same has been happening since i upgraded to the Kona 3. I don’t even think it’s a setting within my version of FCP (6.0.4) becuase when i plugged the firewire from the Io into my MBP and captured i had the same problem as i got on my Mac Pro with both the Io and the K3.
    It is most noticable when i view back on a standard flatscreen via composite out – the same footage captured in avid is much higher quality then the footage captured in FCP via Io or Kona 3.
    I hope i have explained myself ok and you may be able to shed some light on my problem.
    Thanks in advance
    Christian
    Christian Vassallo replied 17 years, 11 months ago 7 Members · 18 Replies
  • 18 Replies
  • Bob Zelin
    October 7, 2008 at 12:18 am
    you ask to “bear with me”, but you state –
    “It is most noticable when i view back on a standard flatscreen via composite out – the same footage captured in avid is much higher quality then the footage captured in FCP via Io or Kona 3. ”
    REPLY – the image quality of STANDARD DEF via composite on a “standard flatscreen” – (you mean LCD flat screen) is CRAP !
    Take your Digi Beta composite video output, and stick it into your flat screen composite video input – how does it look – pretty crappy I bet !
    Most flat screen LCD monitors look like crap with standard def – ESPECIALLY with COMPOSITE video !
    Drag that broadcast monitior in from your AVID suite into your room, and do the tests again (and this time, use analog component video, and not composite) – now, how does it look.
    Bob Zelin
  • Christian Vassallo
    October 7, 2008 at 7:18 am
    Hi Bob
    I should have stated that i have been viewing all the captured media on my own broadcast monitor in my suite as well, via both the SDI and RBG output from the Kona 3.
    I know composite out is crappy, but all i meant was that all the problems i can see on my broadcast monitor are more accentuated and easier to point out when viewed via the composite. I have run everything in both the avid suite and my fcp suite and the problem is only there in fcp, so i was wondering if you were aware of a similar sort of jagged edge problem occurring with fcp before, and what i need to do right to avoid it.
    Cheers
  • Stuart Simpson
    October 7, 2008 at 10:45 am
    Have you tried capturing to a different codec to see if the problem persists? Prores HQ, or DV50?
    -Simmie
    4 MacPros – Kona 3 & Kona LH
    2 G5s – Kona LH
    xbox360, Wii, PSP, PS2
    https://www.speak.co.uk
    October 7, 2008 at 10:59 am
    Hi – yeah i tried capturing in DV50 and the problem was still there. What other codecs would you recommend i try?
    Christian
  • Walter Biscardi
    October 7, 2008 at 11:05 am
    [Christian Vassallo] “It’s pretty good, but I have noticed a few jagged edges on some high contrast areas like peoples sleeves, if they’re wearing a white t shirt for example. It’s been driving me crazy because i don’t know why it is happening. I know it’s not the tape or the deck because i plugged the deck into an avid suite and the picture was perfect on the broadcast monitor. “
    And you don’t see this just on playback from the deck? High contrast areas can be a problem on digibeta because the footage is compressed on the original recording. High contrast areas show compression more than any other area.
    Viewing via Composite on an LCD standard def monitor will make the footage look the absolute worst it can look.
    Walter Biscardi, Jr.
    Biscardi Creative Media
    HD and SD Production for Broadcast and Independent Productions.
    Read my Blog!
    STOP STARING AND START GRADING WITH APPLE COLOR Apple Color Training DVD available now!
    October 7, 2008 at 11:19 am
    Hi Walter
    I seem to remember you’ve been really helpful in the past.
    Yeah i wish i had never mentioned the composite now – please ignore that comment – i have captured the same media in avid and fcp and viewed both assets on a broadcast monitor and the footage captured in avid looks how it should, with as clean lines as you would expect from SD digi, and the footage captured in fcp viewed on the same monitor is visibly poorer quality.
  • Stuart Simpson
    October 7, 2008 at 11:28 am
    If you still see it on the DV50 and Prores captures then I’m stumped.
    I have had a lot of digi material lately with excessive edge enhancement though, mostly when we’ve used the DVW-970P. Dunno if the default setting is too high… Could it be a problem with your camera?
    -Simmie
    2 G5s – Kona LH
  • Walter Biscardi
    October 7, 2008 at 11:29 am
    Are you using a proper Easy Setup in FCP or did you create your own Custom Setup? Sounds like too much compression is being added in FCP.
    If you’re working with 10bit PAL SD, then just use the AJA Kona 3 PAL 10bit SD Easy Setup and don’t change anything.
    Read my Blog!
    October 7, 2008 at 11:38 am
    That exactly what i did – ctrl Q – then selected AJA KONA 3 PAL 10 bit Uncompressed. Frame rate @ 25fps
  • Gary Adcock
    October 7, 2008 at 1:30 pm
    [Stuart Simpson] “If you still see it on the DV50 and Prores captures then I’m stumped. “
    WHAT are the RT settings? turn them to “safe rt” and look again.
    My guess is that this is an issue with the RT engine not delivering full quality outputs on lesser machines.
    FYI -ProRes content played back on NON-Intel machines cannot not be viewed at full quality until rendered!
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    Inside look at the IoHD
