Activity Forums Apple Final Cut Pro Legacy capturing different formats in fcp5
  • capturing different formats in fcp5
    Posted by Joseph Stillman on December 9, 2005 at 1:56 am
    If you are using hdv, dvcam and dv footage in the same timelime, is there any way to capture it and use it without rendering the clips when used in an hdv timeline setup? thanks.
    i cannot read your newsletter in html. can you send it in text? thanks
    Shane Ross replied 20 years, 9 months ago 2 Members · 1 Reply
  • Shane Ross
    December 9, 2005 at 5:35 am
    To work with various formats of footage in a sequence without rendering you need to capture all the footage using the same codec.
    First off, DVCAM and MiniDv is exactly the same format…DV/NTSC. The only issue is working with it in an HDV timeline. HDV and DV don’t mix, and I don’t think you can convert DV into HDV given it’s MPEG-2 compression.
    Best solution? Capture your HDV footage as DV and work in a DV timeline. DV upconverted to 1080i will look really bad…taking a 720×480 image and resizing to 1920×1080.
    If you are going to mix the two, work in a DV timeline. The cameras and decks downconvert on the fly.
    Or get a capture card and decks capture both at a different format entirely, like DVCPRO HD.
    (Who said editing was easy?)
