Activity › Forums › Apple Final Cut Pro Legacy › Capturing clips from a Sony PD170
  • Capturing clips from a Sony PD170
    Posted by Stephan Cotton on August 2, 2009 at 9:51 pm
    After successfully capturing about 1/3 of the clips from a tape, I started getting an error message “Batch Capture: Timecode Error: Unable to locate the specified timecode. You may have specified a timecode with insufficient room for a pre/post roll operation.” (The clip in question was in the middle of the tape.)
    I then restarted the computer and camera and got the message “Warning: You are about to capture Drop Frame media from a device currently detecting or configured for Non-Drop Frame media. If you proceed, you may experience changes in logged in and out points, problems relinking media, or removal of master clip relationships.”
    I am unable to capture the remaining clips. Anyone seen this before? Any solutions?
    Many thanks to all.
    Steve
    Stephan Cotton replied 17 years, 1 month ago 2 Members · 2 Replies
  • Rob Grauert
    August 3, 2009 at 1:35 am
    Did you break the timecode? That would cause issues even if you are in the middle of the tape.
    I can’t help with the drop-frame issue though.
    Robert J. Grauert, Jr.
    http://www.robgrauert.com
  • Stephan Cotton
    August 4, 2009 at 10:11 pm
    I did break the timecode; I turned the camera off and on over the shoot. I thought it would be continuous, so I need to check my settings. Meanwhile, I’m using Capture Now to get it done. Fortunately, it was a short shoot. Thanks for the answer. Steve
