Activity Forums Adobe Premiere Pro Capturing Canon C100 footage
  • Capturing Canon C100 footage
    Posted by Joey Williams on May 24, 2013 at 8:30 pm
    I’m having trouble capturing footage into Premiere Pro from my SD card, which was shot with a Canon C100. Some of the footage is 60i – some is 24p. No ideal, I realize, but when I go to capture, Premiere doesn’t even recognize the card when I insert it.
    I feel like this is one of those, “did you forget to do this obvious thing”, but I’m stuck.
    I’m using Premiere Pro CS6.
    I’m on an iMac 10.8.3
    Any suggestions?
    JW
    TOAD ARRAY
    https://toadarray.com
    Joey Williams replied 13 years, 3 months ago 3 Members · 3 Replies
  • Ryan Holmes
    May 24, 2013 at 9:13 pm
    [joey williams] “I feel like this is one of those, “did you forget to do this obvious thing”, but I’m stuck. “
    Not necessarily…I’ve had PPro not want to read the card from C300 before. Not sure why. I’ve grown accustomed to using Prelude to ingest media. I’ve never had it not see the card (provided the director structure is in place).
    You can also Canon XF utility to pull the clips out and make them self-contained MXF files. Then you can drop those into PPro or transcode to your codec of choice.
    Ryan Holmes
    http://www.ryanholmes.me
    @CutColorPost
  • Al Bergstein
    May 26, 2013 at 11:50 am
    Your mac card reader might not be capable if it’s a newer card. Try an external usb card reader.
    Al
  • Joey Williams
    May 28, 2013 at 2:14 pm
    Thanks, Ryan! I installed Canon’s Utility Import tool, and the MTS files imported perfectly.
    In the past, I always assumed FCP/Premiere would ingest these formats easily, since they are widely used. Luckily I didn’t toss the Canon software.
    JW
    TOAD ARRAY
