Activity Forums Apple Final Cut Pro Legacy Capturing BetaSP with BlackMagic Decklink Extreme HD
  • Capturing BetaSP with BlackMagic Decklink Extreme HD
    Posted by Brett Deacon on January 30, 2009 at 1:46 am
    I have am running FInal Cut Pro 6.05. I have a BetaSP deck (standard) connected to a Blackmagic Extreme HD card. I have the easy set-up at uncompressed 8-bit, NTSC standard. I can control the deck AND receive audio, but for some reason cannot capture any video (a monitor confirms that video is in fact playing. The deck is connected to a blackburst generator for reference. The error message I get is the video is insufficient size.
    I have checked the component cables (using two different sets that had been proven to have worked in the past).
    Any thoughts would be appreciated.
    Brett Deacon replied 17 years, 3 months ago 3 Members · 3 Replies
  • Jaap Verdenius
    January 30, 2009 at 3:34 pm
    What happens when you run the tape and do Capture Now (no In/Out points)?
    Jp
  • Dino
    January 30, 2009 at 5:32 pm
    What model is the deck?
    What is the monitor connected to?
    Are you getting a preview in the capture window but no image on capture?
    Have you checked the component cable by feeding the deck into a monitor?
    Is the Decklink control panel set for component? (those connections double for composite and s-video)
  • Brett Deacon
    January 30, 2009 at 7:10 pm
    It’s a sony 1800
    The monitor is connected to the composite output on the deck.
    I have not checked the component cables, but I have used two of them that have worked in the past.
    The decklink control is set for component.
