Activity Forums Apple Final Cut Pro Legacy Capturing Betacam SP –
  • Capturing Betacam SP –
    Posted by Ashton Kennedy on May 3, 2014 at 1:00 am
    Anybody done this before?
    I have a mac pro running FCP7 and I’m trying to capture through my Kona 3 card from the PVW – 2800 deck. I have the remote 9 pin connected and the computer can control the device but I’m not getting any video/audio signal when I hook the composite out to the In SDI on my breakout box.
    Is it an issue of digital/analog?
    If so how should I connect the deck?
    Ashton Kennedy replied 12 years, 4 months ago 3 Members · 3 Replies
  • Shane Ross
    May 3, 2014 at 2:48 am
    [Ashton Kennedy] “Anybody done this before?”
    Tons. Still do.
    [Ashton Kennedy] ” I’m not getting any video/audio signal when I hook the composite out to the In SDI on my breakout box.”
    Because the Kona 3 doesn’t take in a Composite signal. That connector is an SDI connection…a digital connection. Your deck and that card cannot work together. You need to rent a deck/player that has SDI out. Such as the J-30SDI. The Kona card only does SDI input…it doesn’t do Composite nor Component input…only output. The Kona LHi did Analog Component and composite input.
    [Ashton Kennedy] “If so how should I connect the deck?”
    To a computer with a different capture card…or get a different deck. A digibeta deck will do…
    Shane
    Little Frog Post
  • Steve Eisen
    May 4, 2014 at 3:07 am
    Or rent an AJA IoHD that has Composite In.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Creative Pro Users Group
  • Ashton Kennedy
    May 4, 2014 at 3:11 am
    Thanks For The Feedback And Suggestions. I Had A Feeling It WAs An Issue With It Not Reading Analog. Will Reconfigure.
