Activity Forums Apple Final Cut Pro Legacy Capturing Betacam SP M&E
  • Capturing Betacam SP M&E
    Posted by Karl Gonzalez on June 20, 2011 at 4:42 pm
    I’ve been trying find a way to capture channels 3&4 on a few tapes that I need the M&E off but I haven’t had any luck. The owner of the company was told the purchase the Blackmagic Intensity Pro card but I’ve been told you still can’t control the device in FCP to choose which audio channels to capture.
    Before we had the card I had been using a Canopus converter to capture from the betacam deck when just ch. 1&2 of audio were needed. So far it seems like the best way to go would be to purchase the Intensity Shuttle.
    Just looking to find out if that is going to be the best way or if there is any other way to capture ch. 3&4.
    Just in case the deck model number is UVW-1800.
    Steve Eisen replied 15 years, 3 months ago 6 Members · 9 Replies
  • 9 Replies
  • Rafael Amador
    June 20, 2011 at 5:18 pm
    Instead of plugging the video card to the Betacam CH1 and CH2, why don’t you plug them to CH3 and CH4?
    rafael
    http://www.nagavideo.com
  • Karl Gonzalez
    June 20, 2011 at 5:19 pm
    There aren’t ch. 3&4 outputs.
  • Shane Ross
    June 20, 2011 at 5:20 pm
    Well, the UVW-1800 only plays 2 channels…CH1& 2, not 3&4. You’ll need a different deck, one with 4 channels of output. And the intensity…it only captures two channels of audio. So you would have to only capture 3&4, and do a separate pass for 1&2 if needed.
    Shane
  • Shane Ross
    June 20, 2011 at 5:25 pm
    [Karl Gonzalez] “There aren’t ch. 3&4 outputs.”
    That’s what I am saying. You need a different deck. One with 4 channels of output.
    Shane
  • Scott Sheriff
    June 20, 2011 at 5:45 pm
    [Karl Gonzalez] “I’ve been trying find a way to capture channels 3&4 on a few tapes that I need the M&E off but I haven’t had any luck. The owner of the company was told the purchase the Blackmagic Intensity Pro card but I’ve been told you still can’t control the device in FCP to choose which audio channels to capture.
    Just in case the deck model number is UVW-1800.”
    You need something like either a BVW 75 or PVW 2800.
    Scott Sheriff
    Director
    https://www.sstdigitalmedia.com
    I have a system, it has stuff in it, and stuff hooked to it. I have a camera, it can record stuff. I read the manuals, and know how to use this stuff and lots of other stuff too.
    You should be suitably impressed…
    “If you think it’s expensive to hire a professional to do the job, wait until you hire an amateur.” —Red Adair
  • Rafael Amador
    June 20, 2011 at 7:07 pm
    Sorry haven’t paid attention to the model.
    rafael
  • Larry Asbell
    June 20, 2011 at 8:46 pm
    No a PVW-2800 does not have the 4 channel feature.
    The BVW-75 does, as does the BVW-70, BVW-65 and BVW-60.
  • Larry Asbell
    June 20, 2011 at 9:07 pm
    Oh, also the DVW-A500 will play a BetaSP tape with 3&4 audio.
    Probably all the J series, BetaCam SX and Betacam IMX decks do also.
  • Steve Eisen
    June 21, 2011 at 4:12 am
    You also need the correct capture card. The MXO 2, Kona 3, etc.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
