Activity Forums Compression Techniques Capturing Beta SP for file send
  • Capturing Beta SP for file send
    Posted by David Patterson on September 2, 2012 at 1:54 pm
    I am trying to be sent (NTSC) footage from the States which comes from an old 4:3 Beta SP tape.
    I have received a few different versions but the results have had poor playback (pixely footage as if were a 1999 internet stream).
    I think the problem is that he is sending the footage “uncompressed” at a higher bit rate than what would be used for DVD (does that make sense to you guys or am I spouting nonsense?).
    He is using something called Media100 to capture. What settings should he be using to send me a quality file I can use for DVD use (format, codec etc)
    Thanks for any help.
    David Patterson replied 14 years ago 1 Member · 1 Reply
  • David Patterson
    September 3, 2012 at 8:49 pm
    Just a quick bump – I really apologise – but I’m really stuck for an idea here.
