Activity › Forums › Apple Final Cut Pro Legacy › Capturing audio tracks 3 and 4
Posted by Chet Wesley on January 4, 2008 at 9:09 pmI am trying to capture audio from a tape that is split into 4 tracks. The first two tracks captured with my initial capture of the video, but I do not see a way to capture audio tracks 3 and 4.
Any tips?
Grant Strac replied 18 years, 5 months ago 4 Members · 6 Replies -
Walter Biscardi
January 4, 2008 at 9:22 pmDo you have all four channels of audio feeding in to your system?
Do you have Channels 3 and 4 turned on in the Clip Setting window?
Walter Biscardi, Jr.
Biscardi Creative Media
HD and SD Production for Broadcast and Independent Productions.STOP STARING AND START GRADING WITH APPLE COLOR
The new Color Training DVD now available from the Creative Cow! -
Bouncing Account needs new email address
January 4, 2008 at 9:24 pmVirtually all camcorders with the DV format can playback Ch. 3 & 4, but you need to switch them to that mode (likely in the MENU settings for audio).
Likewise, FCP must be set to access Ch. 3 & 4.
Here’s how (it is the same for PAL, but you will of course use the PAL settings):Final Cut Pro (menu pull-down) >
Audio/Video Settings >
Capture Presets >
Click the “Duplicate…” button >
a new “Capture Preset Editor” window will open >
Change the “Name:” field to DV NTSC 32 kHz CH 3&4 (so you’ll be able to tell it apart from the “normal” setting.)
Under QuickTime Audio Settings >
Input: Second 2 Channels >
Click “OK”Now, try a capture. If the audio is on CH 3&4, you’ll get it into FCP.
Remember to put your “normal” settings back (to “First 2 Channels”) after you captured CH 3&4 tracks.
Grant Strac
February 27, 2008 at 2:29 amis there a way with an hdv deck to caputre all four channels at the same time, if my deck is capable to do that?
Chet Wesley
February 27, 2008 at 3:49 amAs far as I know from the advice I have gotten here on this forum, this is not possible to do through firewire.
Grant Strac
March 7, 2008 at 1:20 ami have a black magic capture device can i do it with that hooking my camera into it?
