Activity › Forums › AJA Video Systems › capturing audio from a NAGRA
Posted by Howard Wexler on April 9, 2009 at 12:54 amI want to capture audio from a Nagra, with no video, thru my Kona LH into FCP….Any advice?
hwJason Levy replied 17 years, 5 months ago 4 Members · 3 Replies -
Bob Zelin
April 9, 2009 at 10:24 pmgenlock with Pilot tone
(oh, I crack myself up).Do you mean that you are using the antique reel to reel Nagra. Why use FCP and AJA at all – there are wonderful Steenbecks and KEMS out there – thats what the REAL FILM EDITORS work with.
I guess Grandpa never heard of Zaxcom.
The answer to your question is that you take the ANALOG AUDIO OUTPUT of your Nagra (is it on a bananna plug ?), and go into the ANALOG XLR INPUT of the AJA Kona LHe. You will need a bananna plug to XLR cable (I guess you are making that up, because no one sells these !).
On your FCP system, in Audio/Video settings, go to NON CONTROLLABLE DEVICE, because even if you have a Nagra IV, Final Cut Pro does not acknowlege linear time code. You could get a Horita box to force your linear time code signal into the RS422 port, but you will probably forget time code (I bet you have a Nagra III) and just send in your audio “free run”. Will it lock up ? What the hell do I know – the Nagra is pretty damn stable, and it should lock up with your picture.
Even if you have a Nagra T, you will still face the same sync issues.
By the way, Stefan Kudelski says “thanks for still thinking about me”.
Bob Zelin
Warren Eig
April 10, 2009 at 7:26 amDo you have to go through a resolver first to account for tape stretch etc., in order to maintain crystal sync? with 24 fps film, I assume you did use crystal sync and shot double system to film.
Warren
Warren Eig
O 310-470-0905email: warren@babyboompictures.com
website: https://www.babyboompictures.comhttps://www.babyboompictures.com/BabyBoomPictures/AFX.html
https://www.babyboompictures.com/BabyBoomPictures/KnitWits_Movie.html
https://www.imdb.com/name/nm0251670/EDITING REEL: https://www.babyboompictures.com/BabyBoomPictures/Editing_Reel.html
TITLE DESIGN: https://www.babyboompictures.com/BabyBoomPictures/Titles_Reel.html -
Jason Levy
April 23, 2009 at 4:29 pmWow, havn’t heard the term “pilot tone” in a long time. I feel a bit .. ill. Where did my youth go?
