Activity Forums Apple Final Cut Pro Legacy Capturing and audio sample rate?
  • Capturing and audio sample rate?
    Posted by Zeke Meginsky on May 13, 2011 at 2:33 am
    I logged and batch captured a lot of clips from one tape. I got this message after:
    “The audio sample rate of one or more of your captured media files does not match the sample rate on your source tape. This may cause the video and audio of these media files to be out of sync. Make sure the audio sample rate of your capture preset matches the sample rate of your tape.”
    Now, I don’t know anything about the camera it was taped from. I heard I have to change something in Easy Setup. What should I change the audio sample rate to? What are the most common settings?
    Thanks in advance..
    Michael Gissing replied 15 years, 4 months ago 2 Members · 4 Replies
  • Zeke Meginsky
    May 13, 2011 at 2:59 am
    It’s a regular MINI DV tape, if that helps.
  • Michael Gissing
    May 13, 2011 at 3:28 am
    Mini DV can be shot with 4 channel audio and a sample rate of 32khz instead of the normal 2 channel 48khz.
    So check your tapes. When playing back in your camera or a deck it should display the sample rate. If it is 32khz then search this forum as the steps to creating an Easy Setup for this have been well covered before.
  • Zeke Meginsky
    May 13, 2011 at 11:32 am
    Okay. So you’re saying I can see the audio sample rate in the tape deck while I’m logging and capturing. How do I see it? Thanks.
  • Michael Gissing
    May 14, 2011 at 12:14 am
    My experience is that the on screen display in many cameras or the display on decks indicates the audio sample rate. I used to own a Sony DSR1500 which showed sample rate on the front panel LCD. Have a look at you devices manual to find out how to display audio sample rate info. You didn’t mention what you are capturing off so I can’t be more specific than that.
