Activity › Forums › Adobe Premiere Pro › Capturing a frame….I can’t seem to import an mpeg and capture a frame so that I have a photo for my websight
  • Capturing a frame….I can’t seem to import an mpeg and capture a frame so that I have a photo for my websight
    Posted by Lars Stolte on April 25, 2005 at 1:14 pm
    I have tried to import an mpeg to Adobe Premiere Pro so that I may export a frame so that I have a picture for the mpegs on my websight. What is the best way to get a frame for my websight?? I am using windows media center.
    Ron Weber replied 21 years, 5 months ago 3 Members · 2 Replies
  • David J
    April 25, 2005 at 3:56 pm
    I have the full version of TMPGenc, which includes a preview facility within which you can copy MPEG (or whatever) still frames to the clipboard.
    The free version of TMPGenc from https://www.tmpgenc.net/e_main.html might be able to do this as well. Worth a try.
  • Ron Weber
    April 26, 2005 at 7:23 pm
    I don’t know if this is what you want but I use 6.5 and when I need a single frame for a still, I razor the frame I want. Then select the frame and ctl-shift-m will capture the frame as a TGA file. Save it and then open it in photoshop. Go under filters, video and de-interlace the frame. Hope that’s what your looking for. Good luck
