Activity Forums VEGAS Pro capturing a complete vhs tape
  • capturing a complete vhs tape
    Posted by Martin Healy on September 28, 2005 at 5:40 pm
    Hello all,
    I am currently vhs tapes onto vegas5 using a canopus advc300.I want to be able to capture the entire tape unattended and then cut the gaps in the footage.At the moment vegas stops capturing every time the tape reaches a blank spot.What do I need to tweak?
    thanks in advance,
    Martin
    Martin Healy replied 20 years, 12 months ago 3 Members · 6 Replies
  • Peter Wright
    September 29, 2005 at 12:38 am
    Maybe you still have Scene Detection (in Cature preferences) enabled, in which case turn it off, although I thought this only worked with DV tapes.
    Device control should also be switched off, but I assume this is so already if you’re using the Canopus converter.
    Peter Wright
    Perth, Western Oz
    http://www.allroundvision.com.au
  • Martin Healy
    September 29, 2005 at 5:00 pm
    Hi Peter,
    Thanks for your reply.Scene detection is off but device control is on because vegas will not capture from the canopus when device control is off.
    Martin
  • Edward Troxel
    September 29, 2005 at 6:49 pm
    What about the “Stop capture on dropped frames” setting?
    Edward Troxel
    JETDV Scripts
  • Martin Healy
    September 29, 2005 at 10:28 pm
    HI Edward,
    Stop capture on dropped frames is not ticked so it can’t be that either.
    Martin
  • Peter Wright
    September 29, 2005 at 11:39 pm
    Martin – I assume the Canopus has a firewire thru channel which uses device control when a DV device is connected, but as this wouldn’t be needed for VHS capture, have you tried turning it off?
    I know when I use my Mini DV deck as pass through, it will even record fuzzy loss of signal as video if there is a break on the VHS tape.
    Peter Wright
    Perth, Western Oz
  • Martin Healy
    September 30, 2005 at 7:59 pm
    Hi everyone,
    Thanks for your replies. Yes Peter it was a canopus issue: turned off pc control and problem is gone.Cheers!
    Martin
