Activity › Forums › Apple Final Cut Pro Legacy › Capturing
Capturing
Posted by Jared Hawco on December 21, 2007 at 4:28 pmIs there a good way to capture 12-bit mini dv footage instead of 16-bit? thanks.
James Haefner replied 18 years, 7 months ago 3 Members · 3 Replies -
Don Greening
December 21, 2007 at 9:21 pmYou have to create a custom DV NTSC capture preset and change the audio capture bit and sample rates from 16 bit 48K to 12 bit 32K. Go to the Final Cut Pro menu>Audio/Video Settings then click on the Capture Presets tab. Create a copy of the DV NTSC preset using the “Duplicate” button then “Edit” button. Change the audio format to “32.000 kHz 16-bit 2-chan” then click OK
In A/V devices tab click the Options button beside “Audio – Firewire DV”. Change the bit depth to 12 from 16 and the sample rate to 32000.00 from 48000.00
Activate the Log and Capture window (Apple-8) and make sure the capture setting is using the new capture preset you’ve just created and you’re ready to rock and roll.
– Don
James Haefner
February 26, 2008 at 4:26 amTwo questions regarding the capturing post.
1) I made a DV NTSC copy in the capture presets tab. However, where’s the field where I can change the audio settings? “32khz from 48khz?
2) After that setting is in place you suggest going to the A/V devices tab and click the options buttons. However, when I click the options button nothing happens.
Look forward to the feedback. Thanks!
James Haefner
