Activity Forums Apple Final Cut Pro Legacy Capturing 50i footage
  • Capturing 50i footage
    Posted by Michael Moser on July 25, 2009 at 3:04 pm
    I’m trying to capture some DV footage from a DVCam tape that was recorded at 50i.
    I’m using the trusty Z1 to play it back through firewire. My device control setting is FireWire PAL and the capture preset is DV PAL 48Hz. The camera is playing the tape back perfectly fine; I can see it and hear it. The firewire output from the camera is set to DVCam, however no video is coming through. What am I doing wrong?
    Michael Moser
    Michael Moser replied 17 years, 2 months ago 3 Members · 4 Replies
  • Chris Gormlie
    July 25, 2009 at 5:11 pm
    Where can you see and hear it? On the Z1’s lcd?
    Do you have deck control over the FW cable?
    Under the Menu setings of the Z1 in VCR mode, Scroll down to IN/OUT REC (the 2 arrows) and ensure you’re in DV mode or auto for the VCR output. Check that the A/V-DV out is ON.
    Failing that, try a different FW cable. If still no luck, try a different deck/camera if you can. I know that at least one of our Z1’s has a hookey FW out.
    Good Luck.
  • Nick Griffin
    July 25, 2009 at 9:16 pm
    Assuming you’re the same Michael Moser I went to school with, let me know if you need to borrow our DSR-25 so you can capture the footage through the analog outputs.
    Also, give me a call sometime so we can chat.
  • Michael Moser
    July 26, 2009 at 12:18 am
    Yes Fan Fan.
    -m
  • Michael Moser
    July 26, 2009 at 1:35 am
    YES
    YES
    >>Under the Menu setings of the Z1 in VCR mode, Scroll down to IN/OUT REC (the 2 arrows) and ensure >>you’re in DV mode or auto for the VCR output. Check that the A/V-DV out is ON.
    I tried it in “auto” and “DV”, and checked the other parameters. All was where it should be in the camera.
    >>Failing that, try a different FW cable. If still no luck, try a different deck/camera if you can. I know >>that at least one of our Z1’s has a hookey FW out.
    The cable and connector have been working fine up til now. I’m going to try my (or Nick’s) DSR-25 and see if that works. If that doesn’t work, I’ll try component in through an AJA unit to another computer.
    Pretty weird. It’s supposed to work.
    -M
    -m
