Activity Forums Apple Final Cut Pro Legacy Capturing 50fps DVC Pro HD Varicam Problem
  • Capturing 50fps DVC Pro HD Varicam Problem
    Posted by Steve Price on October 6, 2009 at 4:14 pm
    I’m trying to capture some DVC Pro HD Varicam footage shot at 50fps. It seems to go in ok, but when I play it back the clip ends way before the point where I pressed ‘escape’ to stop the capture. It plays at half speed ok, but doesn’t reach the end of the clip. If I select to ingest the audio too I hear the sound playing back at normal speed right up to the point where I pressed ‘escape’.
    I’ve been digitising 25fps footage all day with no problem.
    My capture/input is set to AJA Kona LH: 720p 25 DVC Pro HD Varicam.
    How do I get the whole of the clip I need?
    Steve.
    Jeremy Garchow replied 16 years, 11 months ago 2 Members · 1 Reply
  • Jeremy Garchow
    October 7, 2009 at 2:46 am
    What deck and what system hz?
    Did you happen to start capturing on bars? If so, don’t. I’d suggest log and capture as well, instead of capture now.
