Activity Forums Apple Final Cut Pro Legacy Capturing 4 channels of audio using Final Cut
  • Capturing 4 channels of audio using Final Cut
    Posted by Kclark on January 31, 2006 at 8:42 pm
    Is it possible and if yes what is the procedure for capturing into Final cut video and 4 channels of audio from a DVCAM deck via firewire.
    Jeff Carpenter replied 20 years, 7 months ago 3 Members · 2 Replies
  • Mark Maness
    January 31, 2006 at 8:55 pm
    Just make sure that whatever capture preset that you are using allows for four channels of audio. Otherwise, you’ll have to edit a capture preset to allow for four channels of audio and then you have to select them in your batch capture window.
    _______________________________
    Wayne Carey
    Schazam Productions
  • Jeff Carpenter
    January 31, 2006 at 8:57 pm
    I believe firewire only allows two channels at once.
    So you’ll have to capture twice. Once for V/A1/A2 and once for A3/A4.
