Activity › Forums › Apple Final Cut Pro Legacy › capturing 4 channel audio? help needed a.s.a.p
  • Walter Biscardi
    July 21, 2005 at 5:34 pm
    You need to capture in two passes with 4.5. Simply send channels 1 and 2 from your deck to 1 and 2 in FCP. Then for the second pass, send channels 3 and 4 from your deck to 1 and 2 in FCP. I used to have to actually move the audio cables in teh back of the deck to do this.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Neil Harris
    July 21, 2005 at 5:38 pm
    thanks – we are taking the cables apart at the moment to sort it manually – how do you change channels 3 & 4 in FCP???
  • Walter Biscardi
    July 21, 2005 at 5:42 pm
    [neil harris] “thanks – we are taking the cables apart at the moment to sort it manually – how do you change channels 3 & 4 in FCP???”
    You just manually drag the audio down to tracks 3 and 4 in an FCP timeline. For the actual capture, FCP will just be capturing Ch 1 and 2 again.
