Activity Forums Apple Final Cut Pro Legacy Capturing 24p DVCPro 50 with FCP Academic – C’est possible?
  • Capturing 24p DVCPro 50 with FCP Academic – C’est possible?
    Posted by Joni Church on August 13, 2008 at 4:05 pm
    Hello,
    I’ve got a bunch of 24p DVCpro 50 footage to capture with the Panasonic 1200A deck via firewire (was shot on the SDX-900), and I’m getting the “encountered a problem… could be source tape… etc.” error when I try to capture.
    I did come across this post: https://forums.creativecow.net/thread/8/926372#927091 and some other related threads, but I think I have all of my settings correct so I’m wondering what could be up.
    The only possible reason I can come up with is that I’m using a machine that has the academic version of FCP 6.0.4 loaded (my regular machine is tied up with another project and I can’t use it to test my theory), and perhaps it doesn’t support DVCPro 50. Is that possible?
    The deck is set to manual on 022, and 422 (#0002) on 023, as well as firewire on 600.
    The DV50 Easy Setup settings don’t solve the problem. The reason I’m thinking it might be the academic version is that I can capture fine using DV NTSC 48kHz. What do you think?
    Thanks a lot,
    Joni
    Jeremy Garchow replied 18 years ago 3 Members · 8 Replies
  • 8 Replies
  • Kevin Monahan
    August 13, 2008 at 4:36 pm
  • Jeremy Garchow
    August 13, 2008 at 4:40 pm
    I think Academic is a full version of FCP, but I could be wrong. The only difference is that you can’t upgrade the academic version.
    It’s all about the deck settings. Make sure that you don’t have a tape in the deck when changing the settings. I will have to double check your posted settings to make sure that you got it all. This is definitely possible though.
    Jeremy
  • Joni Church
    August 13, 2008 at 4:46 pm
    Thanks a lot for your help and for double-checking.
    I’m considering reverting back to my full version of FCP 5 on this machine to see if it helps, but I really don’t want to do that. I’ve got the deck rented for one day and you know how it is when you’re eating up time. I haven’t had to work with DVCPro50 before, it’s always been HD so this is new. I assumed it would be simpler. Ha!
  • Jeremy Garchow
    August 13, 2008 at 4:47 pm
    Check menu 895 and change the 50M -> DIF OUT to 50M (number 0000).
    Jeremy
  • Joni Church
    August 13, 2008 at 5:00 pm
    I think that I would like to buy you a car.
  • Jeremy Garchow
    August 13, 2008 at 5:12 pm
    Sweet!
    https://automobiles.honda.com/fcx-clarity/
    Except I don’t live in Southern Cali.
    One of these would be cool too with all wheel drive for our harsh Chicago winters:
    https://www.toyota.com/matrix/
    Jeremy
  • Joni Church
    August 13, 2008 at 5:31 pm
    Hehe, seriously though, thanks a lot for your help. No matter how confident I think I am with these Panasonic decks there’s always a sneaky little menu item (or twenty) that I miss.
    I owe you one,
    Joni
  • Jeremy Garchow
    August 13, 2008 at 6:31 pm
    You don’t owe me, I’m just glad you’re up and running.
    The 1200 is a highly menu driven deck and the interface leaves a bit to be desired as all the required settings are spread out all over. The 1400 is a bit easier to use, but it’s similar.
    You should see the higher end SonySR deck. You would swear you are launching the next mission to mars with that thing.
