Activity Forums Avid Media Composer Capturing 16:9 in AV
  • Capturing 16:9 in AV
    Posted by Jamie on February 28, 2006 at 3:53 pm
    Hello there
    Sorry, i’m kind of new to avid. I’ve got footage of both 4:3 and 16:9 format and i need to be able to capture both easily in Avid. How do you switch between the different formats in avid. There has to be an easy way.
    Help would be greatly appreciated.
    Jamie
    Danny Shik replied 20 years, 6 months ago 3 Members · 3 Replies
  • Jonas Hansen
    February 28, 2006 at 4:02 pm
    Is your project going to be 16:9?
    Anyhow, unless you mean HD it really does not matter. If your project is 16:9 your 4:3 footage people will look fat. If project is 4:3 your 16:9 people will look skinny.
    No matter capture should be the same.
  • Jamie
    February 28, 2006 at 5:01 pm
    I have to prepare loads of footage for the web, some of it comes in 16:9 and some in 4:3. It all needs to go onto the web in its original format.
    Any advice
    Cheers
    Jamie
  • Danny Shik
    February 28, 2006 at 10:21 pm
    Jamie
    No problem, just capture normally and have a separate timeline for each format.
    To see the clips in the correct format, right click in the
    Source window and toggle between 3:4 and 16:9.
    Hope it helps
    Danny
