Activity › Forums › Panasonic Cameras › Capturing 1080i 59.94 with 1200A deck – dropped frames on capture
  • Capturing 1080i 59.94 with 1200A deck – dropped frames on capture
    Posted by Joni Church on May 26, 2006 at 9:08 pm
    Hmmm…
    I’m trying to capture some HD footage, and FCP keeps aborting the capture with a dropped-frames error immediately at the beginning of each clip it attempts to capture.
    I’ve been capturing HD with my current setup for about 8 months without running into this problem, but I’m throwing new variables into the mix this time so I’m thinking it might just be something I’m missing.
    I have 24p footage shot on a Fujifilm DVCPRO HD tape with the Panasonic Varicam at 720p. I need to capture it as 1080i at 59.94 due to broadcaster delivery specifications. So I changed the appropriate menu settings in my Panasonic 1200A deck (“Sys Format” from 720p to 1080i and also the menu setting #632 to 720p> HD_OUT> 1080i) in order to capture the 720p stuff as 1080i.
    Capture Preset: AJA Kona 2: 1080i 59.94 DVCPro HD
    Device Control: AJA Kona 2 59.94 Panasonic VTR
    So I’m attempting to capture to two 500GB G-RAID drives (which are striped together as a RAID) via SDI through my Kona 2 card. As I mentioned, I capture material with a similar configuration daily with no trouble.
    I did some research and came across a site that had a list of all the deck settings for the 1200A that need to be set to capture 1080i 59.94, and made sure the settings on my 1200A matched.
    After I received the dropped frames error a couple of times and checked that my set-up is correct (to the best of my knowledge) I tried capturing at 720p 59.94, and it worked flawlessly. I then tried capturing at 1080i 29.97 and that also worked fine. So it seems there’s a hiccup with the combination of 1080i and 59.94, which I can’t figure out.
    I also tried duplicating the capture preset and changing the Advanced Compressor settings to DVCPROHD 1080i60 from Uncompressed 8-bit 4:2:2 to see if that would help, but no dice.
    I posted this on the Apple FCP forum as well, and will be sure to update both posts when necessary.
    Can anyone shed some light? I hope I didn’t leave out too many specifics.
    Thanks a lot,
    Joni
    Joni Church replied 20 years, 4 months ago 3 Members · 5 Replies
  • Joni Church
    May 26, 2006 at 9:45 pm
    For anyone who may be interested in the future, looks like I got a very helpful answer from Shane Ross over in the Apple forum (see below):
    I don’t think your drives, even though they are raided together, are fast enough for 1080i60.
    Plus, you will be wasting a lot of space capturing this way. You shot 720p so capture and edit 720p. When your cut is locked, THEN uprez to 1080i60 (dropping it into a 1080i timeline and rendering) and output.
    But you will still need faster drives for the output.
    That is what I am doing. We shot 720p24, but need to deliver 1080p24 10-bit uncompressed HD. The software uprez looks great.
    Shane
  • >>I then tried capturing at 1080i 29.97 and that also worked fine. So it seems there’s a hiccup with the >>combination of 1080i and 59.94, which I can’t figure out.
    1080i/29.97 **is** 60i. The 59.94 setting is meant for 720p.
    One question, though. I find it hard to believe that your delivery requirement is in the DVCPro HD tape format, especially if it’s 1080/60i. Wouldn’t it be a bit more prudent to either output directly to 720p/60 (as you said you could without problems) and take it to a facility to make the delivery element (I’m guessing that’s probably either HDCam, HDCam SR, or D5), or even to render out your timeline to a 720p/60 Quicktime movie, and take that to a facility on a Firewire drive to accomplish the same thing? In either case, it seems that just getting it to a DVCPro HD tape in 1080i is not accomplishing the creation of your delivery element. Even if you have to take your own 1200 machine to the facility, it will enable them to play back your 720p/60 tape as 1080i directly, provided you have the HDSDI card. In any of these scenarios, it’s not necessary to do what you seem to be having some trouble doing.
  • Walter Biscardi
    May 29, 2006 at 12:22 am
    [Joni Church] ”
    That is what I am doing. We shot 720p24, but need to deliver 1080p24 10-bit uncompressed HD. The software uprez looks great.”
    With a Kona 3 you don’t need to do this any longer. The K3 performs the cross convert on the way out so you can master directly to HDCAM 1080i from a 720p DVCPro HD timeline. We’re going to start doing that here.
    One problem that we have here all the time is the fact that 720p DVCPro HD is Non-Drop Frame both in 59.94 and 23.98 so we have to do some “secret handshakes” on our 720p masters to ensure that the shows start at 01:00:00:02 on the Drop Frame HDCAM masters.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • >>we have to do some “secret handshakes” on our 720p masters to ensure that the shows start at >>01:00:00:02 on the Drop Frame HDCAM masters.
    I don’t know why you would do that. 1:00:00:00 is perfectly valid in drop frame. The scheme for drop frame code is to skip 2 frame numbers every minute EXCEPT for every 10th minute. Minute 00 qualifies as a 10th minute.
    Besides, I don’t recall ever having seen drop frame time code specified for an HD delivery master. In fact, I didn’t even know it existed (it doesn’t exist for 23.98).
  • Joni Church
    May 31, 2006 at 3:47 pm
    My delivery requirement isn’t actually the DVCPro HD tape, I’m sorry if I was unclear. It’s actually HDCAM, at 1080i/60i. So the plan has actually been to take my finished product to another post house who can output to HDCAM for us. Originally I had planned on giving them a 720p/60 QT for them to convert to 1080i and output to HDCAM, but the Post Coordinator there asked if I could provide it in 1080i instead. I didn’t realize my drives wouldn’t be able to handle capturing the material at 1080i/60, so that’s what has begun the whole questioning process.
    I’ve only been working with HD for about 8 months now, and I’ve been sort of hacking my way through it as the only editor where I’m currently working, so the Cow and Apple forums have been extremely helpful. Until this point I’ve been doing strictly 720p stuff so it’s almost like starting over again figuring out my suite’s capabilities with 1080i and what-not.
    Thanks a lot for your help, I’m going with the 720p/60 set-up and providing a QT to the other post house, just as I had originally planned, and as many of y’all have suggested. No worse for wear, though, since I learned a few things along the way.
    Thanks again,
    Joni
    [Mike Most] “>>I then tried capturing at 1080i 29.97 and that also worked fine. So it seems there’s a hiccup with the >>combination of 1080i and 59.94, which I can’t figure out.
