Activity Forums Adobe Premiere Pro Captured with no audio, need audio
  • Captured with no audio, need audio
    Posted by Dex Craig on August 6, 2005 at 7:35 pm
    Hi, all —
    I’ve been searching the forum for the answer to this and can’t find it, so I thought I’d ask.
    I just logged a tape in Premiere Pro 1.5 and didn’t notice that it was set to capture only Video. I did the batch capture and then was surprised, as you might imagine, to find that there was no audio.
    Now, I can’t seem to find a way to recapture the clips with the audio attached. Is there a way to do this?
    Please help! I don’t want to have to go back and re-log the entire tape with the “Audio and Video” option selected….
    Dex
    Dex Craig replied 21 years ago 1 Member · 1 Reply
  • Dex Craig
    August 6, 2005 at 7:42 pm
    In case anyone else has this happen, I exported a batch list (project>export batch list), then imported that batch list and used the imported batch list to batch capture the footage. The audio came along with it, just fine based on the capture settings in the capture window.
    I knew it had to be possible, but I just couldnt’ find it in the documentation.
    – Dex
