Activity Forums Apple Final Cut Pro Legacy captured image innacurate?
  • captured image innacurate?
    Posted by Melissa on May 11, 2005 at 8:42 pm
    I am capturing media in FCP HD through a firewire SONY DSR-1500A drive. The director claims that a few of the tapes that I captured look cooler than they should. I just want to confirm that there is no way I can effect the video or audio input levels when I’m capturing digitally. Is there any way that I could have altered the apprance of the footage from the way it is on the tapes? (I am watching playback in high rersolution and all that…)
    Melissa replied 21 years, 3 months ago 4 Members · 6 Replies
  • Thaxter Clavemarlton
    May 11, 2005 at 8:46 pm
    [melissa] “there is no way I can effect the video or audio input levels when I’m capturing digitally”
    CONFIRMED!
  • Shane Ross
    May 11, 2005 at 9:09 pm
    Where is he viewing this footage? On the computer monitor, or a professional calibrated NTSC monitor connected to your system?
    Try this…connect the deck (while it is connected to your computer) to a NTSC monitor or TV then play the tape. Then play the exact same captured footage and see if it looks different.
    It won’t.
  • Alexander Serpico
    May 12, 2005 at 6:35 am
    Sounds like he or his camera man screwed up… as long as the director knows where to place the blame 🙂
    But of course you can easily correct the color temp anyway later…
  • Melissa
    May 12, 2005 at 11:47 pm
    so far the blame is on me..ugh.
    is there any way that the color temp could have been affected other than with a filter?
    (probably not, huh?)
    May 13, 2005 at 12:41 am
    [melissa] “so far the blame is on me..ugh.
    (probably not, huh?) “
    Nope, and any filter would have to be applied AFTER the import.
    Only people with an ignorance of digital production could assume color could be affected by a direct FireWire transfer.
    Its simply a “file of numbers” that gets transfered from the magnetic DV Tape to the magnetic Hard Disk… nothing gets changed at all.
    There IS only one condition where you SHOULD feel bad about yourself…
    if you choose to ACCEPT any blame whatsoever concerning this issue.
    If there continues to be any “fingers pointed” toward you in this regard, I would excuse myself and extricate myself from this project entirely.
  • Melissa
    May 13, 2005 at 8:03 pm
    thanks for all your help…
