Activity Forums Apple Final Cut Pro Legacy Captured HDV is taking up far less space than expected?
  • Captured HDV is taking up far less space than expected?
    Posted by Errist on October 13, 2006 at 4:22 pm
    I have been capturing HD video from a sony HVR-A1U to an Imac G5. 45 minutes of HD only took up 9GBs, less than the standard DV I capture from the same device. Also the last time I captured HD, on a different computer, it was roughly one GB per minute. The set up is set to HDV 1080i60 and I can’t figure out the reason for the miraculous storage savings. When I play back clips through the viewer, it looks fine. I just don’t want to get through a very long project to find that everything needs to be recaptured. Any help would be greatly appreciated.
    Phillip Van west replied 19 years, 11 months ago 3 Members · 3 Replies
  • Jerry Hofmann
    October 13, 2006 at 5:38 pm
    You’ve done things correctly it sounds like to me… HDV’s data rate is actually LOWER than DV’s…
    HD uncompressed is a different story, as is DVCPROHD.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Errist
    October 13, 2006 at 7:22 pm
    I thought I was capturing uncompressed? Should I not be concerned?
  • Phillip Van west
    October 13, 2006 at 7:57 pm
    HDV is anything but uncompressed. It’s MPEG-2, compressed IN the camera – hence your low (DV-like) data rates of 25 Mbps or less.
    pvw
    Phil Van West
    Terra Nova Productions LLC
    Denver, CO
    Video Production/Post-Production
    G5 DP 2.5GHz / 4.5 GB RAM / OS 10.4.8 / FCP 5.1.2 / QT 7.1.3
