Captured files – video only – kinda’ time sensitive
Hello Cows.
Odd problem that cropped up a while back and is about to cause a major headache.
I’m capturing DV files and getting a “-v” added to the file name on disk. (For example: “test-v.mov” when the clipis logged and loaded as “test”) They play fine in the project, but there’s no audio when played via Quicktime or when imported into a different project.
Details:
FCP 5.1.4 on MacBook Pro (Intel, first generation, so several years old). 2 Gig RAM
1 LaCie 1Terabyte (striped RAID 0) via eSata.
1 Blackstar Pro 400 Gig (from Melrose Mac), also via eSata.
Capture device varies from consumer camera to JVC BR-DV3000 deck.This is a relatively new problem, and I’m about to start loading lots of tapes to an archive drive for a client. Obviously, no audio except within the original project is a problem.
Any ideas? Did a search, couldn’t find this problem.
