Activity › Forums › Apple Final Cut Pro Legacy › capture xdcam on externalHD
Posted by Jurriaan Van der kamp on November 15, 2009 at 9:17 pmHi,
I am thinking about purchasing a new unibody mbp but Apple the dropped the fw400. Now with mij MBP 2.2gHz i capture the sony530xdcam via fw400 and i use my OWC’on the go” externalHD on the fw800 port.Is there a way to work in the same manner with the new “400less”MBP.I mean with the same speed and relieabillity?
PS preferably without spending hundreds of dollars.Andrew Kimery replied 16 years, 10 months ago 3 Members · 5 Replies -
John Fishback
November 15, 2009 at 10:23 pmIf it’s one with an ExpressCard there are FW adaptor cards for that slot. That would avoid reported issues when connecting a camera and drive to the same FW port.
John
MacPro 8-core 2.8GHz 8 GB RAM OS 10.5.5 QT7.5.5 Kona 3 Dual Cinema 23 ATI Radeon HD 3870, 24″ TV-Logic Monitor, ATTO ExpressSAS R380 RAID Adapter, PDE enclosure with 8-drive 6TB RAID 5
FCS 2 (FCP 6.0.5, Comp 3.0.5, DVDSP 4.2.1, Color 1.0.3)Pro Tools HD w SYNC IO, Yamaha DM1000, Millennia Media HV-3C, Neumann U87, Schoeps Mk41 mics, Genelec Monitors, PrimaLT ISDN
November 15, 2009 at 10:48 pmI checked up on the ExpressCards but i stumbeled on a lot mails of people having problems with them.i think the are quite expensive as well (thanx Apple for taking away the fw400). Do you know of a card that works flawlesly and supports hd imx and hdv? on a recent MBP?
John Fishback
November 15, 2009 at 11:02 pmSorry, I have no recommendation for a FW card. I only use a Duel Adaptor (which is an ExpressCard) to transfer P2 card contents in the field. It has worked flawlessly for over two years.
John
November 15, 2009 at 11:08 pmthanks John. This to all the on the road editors with a new MBP. What is the ExpressCard of choice you’all use?
Andrew Kimery
November 16, 2009 at 1:53 amYou could look into buying a FW hub.
All Apple computers only have a single FW bus (even if they have multiple FW ports) and the bus only runs as fast as the slowest device. So you have a FW800 device plugged in and a FW400 device you the single bus will be shared by both devices and run at FW400 speeds.
-Andrew
3.2GHz 8-core, FCP 6.0.4, 10.5.5
Blackmagic Multibridge Eclipse (6.8.1)
