Activity Forums VEGAS Pro Capture with Z7U
  • Capture with Z7U
    Posted by Ted Snow on January 14, 2012 at 4:37 pm
    Is it possible to capture video…either HDV or DV…directly to the computer via the firewire port (pass thru) on the Z7U camera? I did this with my VX2100 when capturing old 8mm home movie film using the capture utility in Vegas. I have gotten the computer to recognize the camera when I turn it on (Device found Sony HVR-Z7U)…but then a dialog box opens up and says
    The device Sony HVR-Z7U could not be opened.
    Please make sure that it is turned on and is not being used by another application or user.
    I have nothing else running on the computer, just Vegas and the Vegas capture app.
    I have ‘Enable DV device control’ unchecked as I always did with my VX2100 since I’m not using a tape (or MRC)…just trying to get video pass thru.
    Thanks a bunch for any ideas or suggestions I might try…if this is even possible with the Z7U. If not…I guess I’ll have to use my VX2100…although I’d really like to try the Z7U for capturing if I can.
    ASUS P8P67 Deluxe MB
    EVGA GeForce GTX 560 Ti 1 GB DDR 5
    Intel i7 2600k 3.4 Ghz
    Corsair HX750 power supply
    Two Seagate Barracuda 500g SATA III drives
    16 Gig G.Skill Ripjaws DDR3 1600
    Canopus ACEDVio card
    Thermaltake V9 BlacX Edition case
    Xigmatek Dark Knight CPU Cooler
    Win 7 Pro
    VEGAS 8.0
    VEGAS 11.0 32 & 64 bit
    Sony VX2100
    Sony HVR-Z7U
    Sony HDR-CX130
    Alesis HD24
    Ted Snow replied 14 years, 7 months ago 2 Members · 4 Replies
  • John Rofrano
    January 14, 2012 at 11:41 pm
    Do you have the Sony HVR-Z7U set to DV downconvert mode? If you’re trying to capture DV it must be in DV mode not HDV mode.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Ted Snow
    January 15, 2012 at 4:43 am
    Thanks for the reply John. Actually I’d like to capture in HDV if possible just because of the resolution. But I’ve never captured pass thru with the Z7U and didn’t know if it was even possible with these cameras. Is the capture utility able to capture a pass thru HD signal?…and if so, does it capture the same file type it records onto the MRC?
    I suppose I could just record the signal to a CF card with the MRC…but I could save some time and extra steps if I can just capture a pass thru signal directly to the PC.
    Thanks a bunch for your help.
    Win 7 Pro
    VEGAS 8.0
    Sony VX2100
    Sony HVR-Z7U
    Sony HDR-CX130
    Alesis HD24
  • John Rofrano
    January 15, 2012 at 4:17 pm
    My Sony HVR-Z1U specs say that it has “Analog/Digital Conversion with Pass-Through” but I’ve never tried it. I’m not sure if the Z7U has this. I just looked and I didn’t see it in the specs.
    ~jr
  • Ted Snow
    January 15, 2012 at 5:44 pm
    Thanks again for the info John. I looked thru my manual and didn’t see anything referring to pass thru either. I guess I do still have a use for my VX2100. It captures a good picture via pass thru but I was hoping for the better resolution with the Z7U. I suppose Sony figured we didn’t need that feature on our cameras anymore 🙂 .
    Makes me curious now about your Z1U with analog/digital conversion pass thru. I wonder if that’s only a signal coming into the A/V jacks to the camera, or if it will actually pass thru the live video feed from the camera to the firewire as the VX2100 does….interesting.
    Win 7 Pro
    VEGAS 8.0
    Sony VX2100
    Sony HVR-Z7U
    Sony HDR-CX130
    Alesis HD24
