Activity Forums Adobe Premiere Pro capture window playback
  • capture window playback
    Posted by Gary Linzer on January 31, 2011 at 10:20 pm
    Hi, When I playback a clip in the capture window the speed of playback goes from normal to fast speed. I use the jkl keys to operate the playback. When I hit the l key to speed up the video playback (it says at the top of the window) it goes from playing to playing at fast speed, but the speed stays the same(at normal) unless I hit the l key three times and then it goes very fast. Is there an way to speed up playback without it going from normal to very fast. In other words are there more than two speeds for playback. In using CS5. Thanks Gary
    Andrew Devis replied 15 years, 7 months ago 2 Members · 5 Replies
  • Andrew Devis
    February 2, 2011 at 5:10 pm
    The speed should increment with each push of j and l, it sounds like a bug of somekind if you don’t get incremental increase or decrease in speed.
    Andrew
    … because it’s all about stories …
  • Gary Linzer
    February 2, 2011 at 6:22 pm
    Hi, thanks for the response. any suggestion what to do? I believe I have the latest updates, but will check. Should I reinstall? Thanks for any additional help.
  • Gary Linzer
    February 2, 2011 at 6:27 pm
    Hi, one further question. Could it be related to my camera. I’m using a Canon XHA1s. Under capture devise I set it to Canon but The XhA1s is not listed so I set it to generic. Do you think this is the problem? If so any suggestions what to do? Thanks,Gary
  • Andrew Devis
    February 2, 2011 at 6:47 pm
    Hi Gary
    Have you tried the control j & l for slow playback? It should also increment speed from v.slow faster with that option.
    Not sure what you should do, maybe contact Adobe support?
    Andrew
  • Andrew Devis
    February 2, 2011 at 6:51 pm
    Hi Gary
    Hadn’t taken in the captures just thinking about playback! Yes, if capturing it is almost certainly a limitation on your camera playback. JKL probably work normally on captured footage in your source monitor. Sorry for the confusion.
    Andrew
