Activity Forums Apple Final Cut Pro Legacy Capture weirdness in FCP 7
  • Capture weirdness in FCP 7
    Posted by Dave Jenkins on August 20, 2009 at 11:09 pm
    I hardly ever do Capture Now but I had three 90 minute betas to capture so I decided to use “Capture Now” with the preference set to “On timecode break: Warn After Capture” Didn’t need the TC. The whole tape appeared to be captured and I got the message at the end that say capture is complete. When I put the clip in a timeline to check it there was only 48 of 90 minutes in the clip (first TC break). When I checked the QT file in the capture scratch folder the whole 90 minutes was there.
    Using an AJA Lhe with FCP 7
    Dajen Productions, Santa Barbara, CA
    MacPro Two 2.8GHz Quad Core – AJA Kona LHe
    FCP 6.0.4 OS X 10.5.5 QT 7.5.5
    Russell Lasson replied 17 years ago 2 Members · 1 Reply
  • Russell Lasson
    August 20, 2009 at 11:39 pm
    How did previous versions of FCP work? There was a timecode break, how would the file work? If I know I don’t need the timecode and if I know there are timecode breaks, I would just change the device control to be a non-controllable device.
    If you open the file in QT Player and change the counter to timecode, does it reflect the timecode break? You could also try deleting the timecode track in QT Player. If the whole clip is there in QT Player, but not FCP, it’s probably that timecode track giving you grief.
    -Russ
    Russell Lasson
    Colorist/Digital Cinema Specialist
    Color Mill
    Salt Lake City, UT
    http://www.colormill.net
