capture w/ HDPVR, vegas 9 cant edit or play it back?
Posted by Kyle Kelly on October 30, 2009 at 9:44 pmi just bought a hauppage HDPVR, and ive had sony vegas 9 for a while. i capture gameplay from my PS3 and edit it in vegas. however when i capture from my PVR and then import into vegas, the clip will play for 3 seconds and then the message “sony vegas 9 has stopped working.” comes up and it closes the program. any ideas?
John Frey replied 16 years, 5 months ago 5 Members · 5 Replies -
John Frey
October 31, 2009 at 1:21 amWhat file format is the PVR recording to? There so many different file formats out there now, it is no wonder Vegas has issues with some of these. One of my HD cameras records mp4 in a Quicktime wrapper as .MOV files. They are 1920 x 1080. Even with Vegas 9.0c, after a while, Vegas stops working. The only program that I have found that can edit these or does a quick convert with multiple output choices is Vision, the rudimentary NLE found in the newer versions of Nero(DVD burning software). The 2-pass to mp4 at 1920 x 1080 is very fast, and the files look untouched(at the highest setting). The HDV ouput setting is also quite good. By the way, if I drop those same original .MOV files in the latest upgrade of Adobe Premeiere Pro CS4,it immediately blue screens and crashes.
John D. Frey
25 Year owner/operator of two California-based production studios.Digital West Video Productions of San Luis Obispo and Inland Images of Lake Elsinore
Stephen Mann
October 31, 2009 at 5:48 amI’ll bet that you’re running into copy protection….
Steve Mann
MannMade Digital Video
http://www.mmdv.com -
Matt Bazkur
October 31, 2009 at 12:44 pmI have Sony Vegas Movie Studio Platinum 9 and I get the same crash when I try to edit an M2TS file from the HD-PVR.
I installed the 30-day trial of Sony Vegas Movie Studio HD and got the same result.
I then installed the 30-day trial of Sony Vegas Pro 9.0c and that app performed beautifully. It played the clip easily and rendered out to M2TS, MP4, and I even tried XDCAM – looked great.
I sent a product suggestion to Sony, asking them to add support for the HD-PVR in Platinum (I can’t afford Pro).
Please do the same if you get the same results.
BTW, Pinnacle Ultimate 12 can handle the file, but IMHO it’s not nearly as nice an NLE as Vegas.
Kevin Yates
March 20, 2010 at 11:54 pmHey did you ever figure out how to bypass this problem? I’m running into the same problem and frankly I have no idea how to solve it. I read the post under this and well.. it doesn’t solve the problem, so if you found out how to fix this can you please respond asap? thanks much mate!
p.s. what the hell is Sony Vegas 9.0c?
John Frey
March 21, 2010 at 3:22 amI ended up turning hardware acceleration all of the way down under the advanced setting/troubleshooting in my display card settings. My card is a triplehead Matrox Parhelia APVE. Both Vegas and Premier no longer crash when playing back these files. Go figure!
John D. Frey
