Activity Forums Blackmagic Design capture using blackmagic, then move to computer without it
  • capture using blackmagic, then move to computer without it
    Posted by Michelle De long on March 21, 2006 at 8:54 pm
    I just want to make sure I have this right.
    If I capture in FCP Black Magic-10 bit NTSC through our Black Magic Extreme Card, have the capture and sequence compression set to Apple Uncompressed 10 bit 4.2.2, I can then copy all of those files to a computer that does not have the card.
    The files and the sequence will play on the computer that does not have the card right?
    Basically we have a client that would like us to on-line digitize their project from Digibeta and transfer the files to their drives so they can color correct the project somewhere else.
    Michelle De long replied 20 years, 6 months ago 2 Members · 2 Replies
  • Kristian Lam
    March 21, 2006 at 10:03 pm
    Hi Michelle,
    Yes, you will be able to use the clips in a machine without any DeckLink cards.
    regards
    Kristian Lam
    Blackmagic Design
  • Michelle De long
    March 21, 2006 at 10:42 pm
    Thanks. That is what I thought.
