Activity › Forums › Apple Final Cut Pro Legacy › Capture to seperate files
  • Capture to seperate files
    Posted by Chris Paul on June 1, 2005 at 9:56 pm
    I normall capture audio & video to a single file as this was recommended by Pinnacle for Cinewave. They said that if this was not done audio & video could be out of sync on recapture. I am changing to the Apple 10 bit CODEC but am still using the Cinewave for capture. Does anyone know if the single file is necessary? I would like to capture audio & video to seperate drives if possible.
    John Pale replied 21 years, 3 months ago 4 Members · 3 Replies
  • Walter Biscardi
    June 1, 2005 at 11:03 pm
    Capture them as one file. Capturing as separate files can cause sync issues and drop frame issues. There is no longer a need to capture anything as a separate file.
    Walter Biscardi, Jr.
    Creative Genius, Biscardi Creative Media
    Now in Production, “The Rough Cut,” https://www.theroughcutmovie.com
  • Rich Rubasch
    June 2, 2005 at 1:10 am
    Walter, I have a project that I digitized 7 hours of beta footage. Most of the clips had nat sound so I digitized audio and video to a single file in the DVcodec for offline. Now, when I redig the video only for the online there is no way for me to delete the huge and long DV video clips from the audio because they are all in a single file. I thought of this after about 5 hours were digitized. Now I wish my audio clips were separate so I could delete the video DV clips after the thing is onlined and keep only the audio.
    If only FCP had a slick consolidate that was as elegant as AVID I would have no problem consolidating the audio to small clips by themselves then batch dig the online video. I have the PipePro Studio and I wonder if uploading to separate AV files would actually cause sync issues.
    There still IS a good reason to digitize to separate AV clips…FCP’s awful media manager!
    Rich Rubasch
    Tilt Media
  • John Pale
    June 2, 2005 at 1:51 pm
    Duplicate your DV sequence. Delete the video clips from the duplicate. Drag into new project (optional–but automatically breaks all links to master clips). Use the “awful” Media Manager to copy the media deleting unused footage. You end up with all your audio consolidated–no video. Paste the consolidated audio back into your Online video only sequence.
