Activity Forums Apple Final Cut Pro Legacy Capture to root or other directory?
  • Capture to root or other directory?
    Posted by Valerie Shoaps on January 12, 2009 at 10:54 am
    Rudimentary question. Is it best to capture to the root of my media drive/s or is FCP OK with capturing to a directory tree (ie. F:Media/project1/)? If going to the root, does having other files in the root wreak any havoc with FCP projects?
    Valerie Shoaps replied 17 years, 8 months ago 2 Members · 2 Replies
  • David Roth weiss
    January 12, 2009 at 5:47 pm
    Valerie,
    Actually a very good question, as getting this right will always insure that your FCP projects are setup properly and setup the way other pros will expect them. These things are best when standardized and used consistently, so that collaborators anywhere can simply sit right down and get to work without having to ferret out someone’s creative directory structure.
    So, when starting a new project always simply choose the root directory of your media drive (in the Easy Setup or in the FCP System Settings) and allow FCP to automatically create it’s own default directory structure, which will automatically create a sub-directory for each new project with the project name that you create when you initially save the project.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Valerie Shoaps
    January 14, 2009 at 10:01 am
