Activity Forums Apple Final Cut Pro Legacy capture to end of tape
  • capture to end of tape
    Posted by Jeffrey Levenstone on November 23, 2005 at 11:16 pm
    Dear fellow editors
    Is there a way to capture an entire tape without knowing the end timecode. I Know about capture now, but does it stop capturing when there is no more timecode or does it just continue until you stop it.
    Thanks in advance,
    jeffrey levenstone
    Arnie Schlissel replied 20 years, 9 months ago 4 Members · 3 Replies
  • David Bogie
    November 23, 2005 at 11:40 pm
    continues till you hit ESCAPE. I once left the building for a moment and got sidetracked. Came back an hour later had had captured an hour of black after the tape ended.
    bogiesan
  • David Roth weiss
    November 24, 2005 at 2:02 am
    Actually Bogie, I don’t think it keeps going anymore. At least not here at my shop. I distictly noticed this “feature” and was very pleased with it, as my previous NLE would capture until the drive was full if left to do so.
    DRW
  • Arnie Schlissel
    November 25, 2005 at 5:57 pm
    I think it depends on whether you have device control set to “non-controllable device” or not. If device control is on, then I think it should stop when it runs out of timecode. If device control is off, then it’s not looking at TC at all, & it’ll just keep running till you tell it to stop. Or your drives fill up.
    Arnie
    https://www.arniepix.com
